Winpopup alerts
  • rjorge99
    • Mar 2008
    • 27
    Winpopup alerts
    Hi, I followed the tutorial for popup alerts:
    I did all the steps, when the action is fired, the script is fired to, and I have in Monitoring ---> Actions that the winpopup was send but the popup never is shown on the PC of the user that suppose must be shown.
    Should I active something in the windows PC where the popup must be shown?
    What other options could I try to test the script and the popup message?
    Thanks!!
  • just2blue4u
    • Apr 2006
    • 347
    Yes!
    On a german system it's called "Nachrichtendienst".
    You can activate/deactivate it in the "Systemsteuerung" -> "Verwaltung" -> "Dienste" (sorry, i don't know the correct english names).
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
    • niekie
      • Apr 2008
      • 16
      Two things come to mind (not tested/verified):
      • Is the Messenger service running on the receiving computer?
      • Is there a firewall blocking incoming messages?
      • rjorge99
        • Mar 2008
        • 27
        niekie:
        Yes, the messenger is running on the receiving computer, and i hasn't firewall activated.
        • niekie
          • Apr 2008
          • 16
          And if you try from the command line of another Windows machine, does your receiving PC accept a message?
          net send <pcname> <message>
          Niek.
