Hi all, I want all the message from agent are sent to mail address [email protected]. How do I fill the field
SMTP server:
SMTP helo:
SMTP email:
thanks
if you run a local Mailserver on the Zabbix Server Machine, you can simply fill in "localhost" for server and Helo. If not, fill in the Hostname or IP of your mailserver.
I set SMPT email to "zabbix@myhostname".
Big ZABBIX is watching you!
(... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
