Escape bars in zabbix_get
  • fast.ryder
    • Apr 2008
    • 46
    Hello, everyone!
    I have come across the solution for a problem I have encountered recently.
    Using the portuguese version of Server 2003, I was never able to get performance data in shell mode (bash) using zabbix_get.
    The command I used for zabbix_agent was:
    zabbix_get -s (ip) -k perf_counter[\Sistema\Threads]
    However, I enabled logging level 4 for the Zabbix agent and my system complained about:
    "cannot find SistemaThreads"
    (Something like cannot find SystemThreads, as if the input was badly parsed..)
    then I added two more slashes and everything went ok:
    zabbix_get -s (ip) -k perf_counter[\\Sistema\\Threads]
    So if anyone else has this problem... please try it out.
    P.S.: Zabbix team, is this a bug? I "RTFM" but did not find any reference to double slashes... (1.6 version)
    Thanks,
    Ivo Pereira
    IT Consultant
    Portugal
  • niekie
    • Apr 2008
    • 16
    This is not a Zabbix bug, this is your shell on Linux eating your '\'. A '\' in a Linux/Unix shell usually indicates that the very next character should not be interpreted but taken literally. So to have "zabbix_get" actually see a '\' you have to '\' the '\' ("escape the escape character").
    Niek.
