Eventlog weird behavior
  • antani
    • Apr 2008
    • 50
    Items:
    eventlog[Security] <- Get correct data (a list of the occurred events)
    eventlog[System] <- Get correct data
    Triggers:
    {myTemplate:eventlog[Security].logseverity(4)}=4 (Works great)
    {myTemplate:eventlog[System].logseverity(4)}=4 (shows uknown)
    WHY???
    What does the 4 in logseverity(4) means? Which other options are available?
    What does the 4 in =4 means? Which other options are available?
    I read almost everywere but cannot find anything i didn't already try.
  • bbrendon
    • Sep 2005
    • 873
    Try combing with an &nodata on there.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • trikke
      • Aug 2007
      • 140
      Hi Antani,
      From source: eventlog.c
      case EVENTLOG_ERROR_TYPE: *out_severity = 4; break;
      case EVENTLOG_AUDIT_FAILURE: *out_severity = 7; break;
      case EVENTLOG_AUDIT_SUCCESS: *out_severity = 8; break;
      case EVENTLOG_INFORMATION_TYPE: *out_severity = 1; break;
      case EVENTLOG_WARNING_TYPE: *out_severity = 2; break;
      So for your trigger to work u will need a "Error type Eventlog message" to match against!
      There is a smal nifty tool "logevent.exe" which alows u to create Eventlog-Messages from cli.
      Greets
      Patrick
      • antani
        • Apr 2008
        • 50
        Thanks. It was very useful.
