Is zabbix the right tool for me?
  • james2012
    • Jan 2008
    I really like the graphing ability of zabbix, but I question its scalability limitations caused by the gui. I am considering setting up zabbix to monitor 500+ hosts running multiple services each. I have some requirements which I have been able to find solutions for in Zabbix. If anyone knows how to solve these issues with zabbix, please share!
    Logging in to 500+ servers to stop a service will obviously not be a good solution. I have an automation tool to do this from a central location. I need to somehow tie zabbix in to this.
    Automation:
    If a zabbix monitored service shuts down because the service_shutdown script was run, I need to automatically disable alerts. Is there any way to do this in zabbix? Either by setting something on the edge clients, or sending something to the zabbix server?
    If If I add a new service to 500 hosts, is there any way to automatically add this new service?
    Using command line based monitoring tools, this is all pretty easy. Its just a matter of having scripts edit/clone/modify config files. The zabbix gui scares me.
    I would really love to use zabbix. Please share any ideas you may have, or experience you may have with monitoring a large number of things in a scalable fashion.
    Thanks!
  • nelsonab
    • Sep 2006
    • 1233
    I'm not sure how you'd do some of it, but for the services you talk about you could set a key to be something like item.service_state and include that key in your trigger. In your init script for the service you would then use the zabbix_sender to send the value of this key. IE, when the service is going up, you send a value of 1. When the service is going down you send a value of 0. In your trigger expression you would say something like:
    if (service not running) and (service_state == 1) then trigger
    RHCE, author of zbxapi
    • Anton
      • 17
      Connect the Hosts with a template, and then add items and triggers to this template - zabbix will add the new items/triggers to all hosts depending on this template.
      but currently, i don't see the possibility to connect all hosts to a new template ...
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        This will be possible with 1.6.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Actually the functionality is already available in the latest betas.
          Alexei Vladishev
          My Twitter
