Cisco router bandwith
  • Wouaf
    • Feb 2008
    • 9
    Hi everybody,
    I want to monitor a bandwith utilization by percent for a cisco 800 series.
    I receive by snmp the value for IfInOctets and IfOutOctets, but i'm not able to used it correctly for display in a graph
    How can I do?
    Thanks for all
  • kilativv
    • Oct 2007
    First of all in the items section you will need to change "Store Value" option to Delta for IfInOctets(and other counters you need)
    I haven't actually converted speed to percentage values but 'Use Multiplier' option should be helpfull I think to calculate percents.
    • nelsonab
      • Sep 2006
      • 1233
      Right now you can't do ongoing percent utilization of a network connection, unless it is given via some other means such as SNMP or an external script.
      One option would be to run an external script that polls the router, determines the delta then figures out how close to max it is then puts that value into Zabbix.
      RHCE, author of zbxapi
