Hello Guys.
I follow this howto for configure DistMon Env....
It is a very nice howto.... i try configure my enviroment from scratch. After start zabbix server, into log appear this lince.
And this strange line
Zabbix server (master and child node) works on port 5001, not on port 10051. Under node (master and child) configuration i have setup port 5001
This is my zabbix_server.conf file ...
Someone can help me to understand the error ??? I'm usign zabbix 1.4.4 with gentoo linux
Maruscya
32181:20080508:164151 NodeID does not match configuration settings. Processing of the node is disabled
1495:20080508:165520 server #206 started [Node watcher. Node ID:0]
# This defines which server this is.
# Default value 1
# This parameter must be between 1 and 255
Server=1
NodeId=1
# Number of pre-forked instances of pollers
# Default value is 6
# This parameter must be between 6 and 255
StartPollers=100
# Number of pre-forked instances of trappers
# Default value is 5
# This parameter must be between 2 and 255
StartTrappers=100
# Listen interface for trapper. Trapper will listen all network interfaces
# if this parameter is missing.
#ListenIP=127.0.0.1
# Listen port for trapping. Default port number is 10051. This parameter
# must be between 1024 and 32767
ListenPort=5001
# How often ZABBIX will perform housekeeping procedure
# (in hours)
# Default value is 1 hour
# Housekeeping is removing unnecessary information from
# tables history, alert, and alarms
# This parameter must be between 1 and 24
HousekeepingFrequency=1
# How often ZABBIX will try to send unsent alerts
# (in seconds)
# Default value is 30 seconds
SenderFrequency=30
# Uncomment this line to disable housekeeping procedure
#DisableHousekeeping=1
# Specifies debug level
# 0 - debug is not created
# 1 - critical information
# 2 - error information
# 3 - warnings (default)
# 4 - for debugging (produces lots of information)
DebugLevel=3
# Specifies how long we wait for agent (in sec)
# Must be between 1 and 30
Timeout=15
# After how many seconds of unreachability treat a host as unavailable
UnreachablePeriod=45
# How ofter check host for availability during the unreachability period
UnavailableDelay=15
# How ofter check host for availability during the unavailability period
UnavailableDelay=60
# Name of PID file
PidFile=/var/run/zabbix/zabbix_server.pid
# Name of log file
# If not set, syslog is used
LogFile=/var/log/zabbix/zabbix_server.log
#Location for custom alert scripts
AlertScriptsPath=/var/lib/zabbix/scripts
#Location of 'fping. Default is /usr/sbin/fping
FpingLocation=/usr/sbin/fping
# Frequency of ICMP pings. Defauls is 30 second.
PingerFrequency=30
# Database host name
# Default is localhost
DBHost=localhost
# Database name
#DBName=zabbix_db
DBName=distmon
# Database user
DBUser=********
# Database password
# Comment this line if no password used
DBPassword=*********
# Connect to MySQL using Unix socket?
DBSocket=/var/run/mysqld/mysqld.sock
# Default value 1
Server=1
NodeId=1
StartPollers=100
StartTrappers=100
#ListenIP=127.0.0.1
ListenPort=5001
# (in hours)
# (in seconds)
SenderFrequency=30
DebugLevel=3
Timeout=15
UnavailableDelay=15
UnavailableDelay=60
# Name of PID file
# Name of log file
PingerFrequency=30
DBHost=localhost
# Database name
#DBName=zabbix_db
DBName=distmon
# Database user
DBUser=********
# Database password
Maruscya
