Hub in map
  • Samuel
    • Apr 2008
    • 26
    Hub in map
    When I include hub icon in map, without host, show the error.
    Warning. Incorrect value for [elementid]
    I don't want host for hub, because its doesn't monitored.
    How I resolv this?
  • antani
    • Apr 2008
    • 50
    How I resolv this?
    You can workaround adding a default null host not monitored.
    The error shows up because zabbix doesn't found an entry for that (or blank name) host/hub in db.
    • Samuel
      • Apr 2008
      • 26
      Zabbix doesn't found host because I don't select host or trigger. But I go include a trigger for solve this.
      Thanks.
