Some mistake into Trigger
  • maruscya
    • Jul 2007
    • 129
    Hello guys...
    Please could you explain me what do this trigger:
    {Fgt_3sg:fnSysCpuUsage.last(120)}>85
    IMHO .. trigger is fired up when value "fnSysCpuUsage" is upto 85 for 120 sec
    Is right ??
  • cstackpole
    • Oct 2006
    • 225
    OK I don't think that expression is right. Here's why:
    Accordding to the manual (Release 12 Pg 119) the argument is ignored in the last function. So that 120 doesn't do anything at all. The trigger you posted I expect will fire everytime fnSysCpuUsage gets above 85.
    I am no master of these commands, but I have done something similar. At least I think this is similar to what you are wanting. Try this:
    {Fgt_3sg:fnSysCpuUsage.avg(120)}>85
    If that doesn't work the way you want it to, give a read through the manual (starting at page 116) at all of the different functions. Maybe you will find something you can use.
    Hope that helps.
    • maruscya
      • Jul 2007
      • 129
      Many thanks for your reply.
      I'm starting test now... i'll keep you update...
      Maruscya
