Zabbix varaibles
  • tore
    • Feb 2008
    • 16
    Zabbix varaibles
    Is there a list of what variables are available in Zabbix by default?
    For example if I want the hosts IP address to show when I send an alert.
    Regards
    Tore
  • Niels
    • May 2007
    • 239
    You could possibly use the {IPADDRESS} macro. Or something from {PROFILE.?}.
    • cstackpole
      • Oct 2006
      • 225
      I believe what he was looking for was a list of all of the items. I believe that the best list you will find is on the pdf document: http://www.zabbix.com/documentation.php
      Try section 5.4.1 on page 80. I think that is what you are looking for.
      • tore
        • Feb 2008
        • 16
        Thanks! I searched in the manual, but couldn't find the list in 5.4.1, guess my mind was searching for "variables".
        Thanks a lot
        Regards
        Tore
