Solaris 9 / ZABBIX Agent / load avg: NOTSUPPORTED
  • NOB
    • Mar 2007
    • 469
    Hi
    during my experiments with a ZABBIX-Server on Solaris 9 (SPARC) and
    the tests of the agent I noticed that system.cpu.load[,avg1]
    et al. are not supported by the agent.
    The reason is, that the wrong macro definition is used in cpu.c
    for solaris.
    Hope this helps others and will be integrated in the next release.
    I am not sure, whether the problem will also appear on Solaris 10 or on other (Intel) platforms.
    Regards
    Norbert.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I believe we fixed this last week in both 1.4.x and trunk.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • NOB
      • Mar 2007
      • 469
      Hi Alexei
      thanks a lot.
      Regards
      Norbert.
      P.S. Verified the fix in trunk 1.5.x (R5900)
      Last edited by NOB; 13-08-2008, 09:32. Reason: Added verification for fix in trunk.
