PATCH: A new cleaner look for number of problems on maps
  • vlam
    • Jun 2009
    • 166
    #16
    can someone please explane to me how to enable this patch in my system so that i can also use it.
    please i begg all any or all of you to help me...
    thanks
    4 Zabbix Frontend Servers (Load balanced)
    2 Zabbix App Servers (HA)
    2 Zabbix Database Servers (HA)
    18 Zabbix Proxy Servers (HA)
    3897 Deployed Zabbix Agents
    6161 Values per second
    X-Layer Integration
    Jaspersoft report Servers (HA)
    • sire
      • Jul 2010
      • 210
      #17
      thanks
      Try starting with
      man patch
      If this doesn't help much try doing the following:
      1) download a patch to /tmp;
      2) cd to a directory containing zabbix web interface - /usr/share/zabbix on my system;
      3) patch -p 2 < /tmp/patch_file_name.patch
      If patch asks you to enter a file name, play with -p option - try increasing and decreasing it, its behavior is explained in the man page.
      Regards,
      Sergey Syreskin
      Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
      Temporary out of Zabbix business
      • sire
        • Jul 2010
        • 210
        #18
        Patch update for Zabbix pre-1.9.6.
        Regards,
        Sergey Syreskin
        • sire
          • Jul 2010
          • 210
          #19
          Patch updates for Zabbix pre-1.8.10 and pre-1.9.9.
          Regards,
          Sergey Syreskin
          • Termi2000
            • Dec 2011
            Originally posted by michal89
            Ya really nice . greaty information here. Keep posting.............!!???
            I am waiting for a patch for RC3.
            I tried bymyself but then I have a white screen and I see nothing.
            Copying back the original files allthings are good.
            please help.....it would be very nice when it is implemented in the finished version 2.0
            thanks termi2000
            • sire
              • Jul 2010
              • 210
              #21
              thanks termi2000
              I'll post the updated versions of my patches soon.
              Regards,
              Sergey Syreskin
              • sire
                • Jul 2010
                • 210
                #22
                Patch update for Zabbix pre-2.0.0.
                Regards,
                Sergey Syreskin
                • Termi2000
                  • Dec 2011
                  perfect
                  thanks for fast response.
                  do you have also a little patch for maps if you click on a host you can go directly to configuration the host?
                  cu
                  termi
                  • sire
                    • Jul 2010
                    • 210
                    #24
                    Patch update for Zabbix 2.0.1. Fixes an issue with grid show/hide in map editor.
                    Regards,
                    Sergey Syreskin
                    • Termi2000
                      • Dec 2011
                      Something new for 2.0.4.......I am waiting of this patch.
                      did someone have a timeline when it comes?
                      thanks in advance.
                      • spector
                        • Apr 2010
                        #26
                        please update patch for 2.0.3
