Submitting patches in the issue tracker
This is a sticky topic.
  • richlv
    • Oct 2005
    • 3112
    It is suggested to create issues in the Zabbix issue tracker:
    Patches can be attached there. Forum could be used for longer discussions.
    You may create an account in the issue tracker to open new issues or comment/vote on existing ones.
    Please search the issue tracker for already reported issues beforehand.
    Before reporting an issue or commenting on one, read bug reporting guidelines.
  • Termi2000
    • Dec 2011
    Please make a feature request for:
    1. Search objects on network maps ......so it was highlighting the search object.
    2. A new cleaner look for number of problems on maps
    I have try and search on the link you give but I didn't found where I can add a new feature request.
    Thanks in advance to make it for me for the two points.
    CU
    • richlv
      • Oct 2005
      • 3112
      you may create an account there. i modified the first post to include that information
