Graphtree For Zabbix3.0.1/3.0.2/3.0.3
  • itnihao
    • Aug 2013
    • 12
    Zabbix graph tree can show all graphs and log in one page
    此项目当前不再更新,只适用于3.0和3.2版本. Contribute to OneOaaS/graphtrees development by creating an account on GitHub.
  • kloczek
    • Jun 2006
    • 1771
    Working with zabbix almost everyone knows that surface on the screen is very precious. TBH I don't think that reserving constantly some part of the screen to display graphs tree is good idea. IMO it would be way better to have ability to organise list of graphs per host in drop down window with hierarchy of the graphs on the host. It would be very important on some hosts where graphs are generated by LLD. Sometimes scrolling very long such flat list is quite annoying and slowes down switching to next graph which you want to see.
    Part of such idea will be how to description in the graph metadata pointing that exact graph must be in exact branch of the tree.
    Solution which I see atm is additional column in graphs table in format like "/level1/level2.../levelN" which could be used on organising graphs in tree view.
    If we are talking about some possible enhanctments just realised that exactly the same idea could be used on extending Application string.
    Now Application string is used only to group all items in only one level deep tree.
    With Application string like "/App/SubApp1.../SubAppN" would be possible to organise browsing all metrics views in "last data" view in full tree view.
    In case some hosts numbers of metrics is bigger than few hundredths or even few thousands. Browsing such lists using one level tree view may be quite painful.
    I'm not sure is proposed additional graphs table column or application extension is the best. Proper low level description must be chosen using three independent criteria:
    - easiness of making SQL queries (string with slashes seems is OK from this point of view)
    - minimum memory consumption and latency on acceding to all graphs/items to display exact branch of the tree
    The same drop down list with hierarchy view could be used as well in hosts screens.
    Comments?
    • itnihao
      • Aug 2013
      • 12
      In many case,drop down window find host group and host very slow, sometimes want to find application's graph so that can get more history.
      1.host group and host in a tree is one query, it's so fast.
      2.It supoort paging and use aync to display graph,so it also fast
      Comments?
      • sancho
        • Mar 2015
        • 301
        Congratulations on the job, after the last update to 3.0.4 zabbix stopped working and has not let me install it again.
        Will he updated to the new version ??
        Sorry for my English
        • slartibartfast
          • Aug 2016
          • 11
          Same issue over here -- graphtree over 3.0.4 is not working.
          • itnihao
            • Aug 2013
            • 12
            Hi,this week,we will update it.
            • sancho
              • Mar 2015
              • 301
              Great,
              Congratulations for your work.
              • slartibartfast
                • Aug 2016
                • 11
                Thank you for all your great work!
                While here, please note to change little bit color of the text (listing of the hosts on the left, if possible) when Zabbix is using Dark theme instead Blue theme as default.
                • itnihao
                  • Aug 2013
                  • 12
                  update and change the style.
                  • sancho
                    • Mar 2015
                    • 301
                    Hello itnihao,
                    Many thanks for your work.
                    I'm doing something wrong, because when I upgrade, selecting the menu "Graphtree" I get an error page:
                    not Found
                    The requested URL was not found /oneoaas/graphtree.php on this server.
                    What am I doing wrong??
                    • itnihao
                      • Aug 2013
                      • 12
                      you patch not OK.
                      HTML Code:
                      wget http://sourceforge.net/projects/zabbix/files/ZABBIX%20Latest%20Stable/3.0.4/zabbix-3.0.4.tar.gz
                      tar xf zabbix-3.0.4.tar.gz
                      cd frontends/php
                      ZBXVERSION=3.0.4
                      wget https://raw.githubusercontent.com/OneOaaS/graphtrees/master/graphtree${ZBXVERSION}.patch
                      #yum install -y patch
                      patch  -Np0 <graphtree${ZBXVERSION}.patch
                      chown -R nginx:nginx oneoaas  (if you ware use nginx web,the user is should be nginx)
                      Originally posted by sancho
                      Hello itnihao,
                      • sancho
                        • Mar 2015
                        • 301
                        /usr/share/zabbix# patch -Np0 <graphtree${ZBXVERSION}.patch
                        patching file ./include/func.inc.php
                        patching file ./include/menu.inc.php
                        patching file ./oneoaas/api/ajax.php
                        patching file ./oneoaas/api/graph.php
                        patching file ./oneoaas/assets/css/animate.min.css
                        patching file ./oneoaas/assets/css/bootstrap.min.css
                        patching file ./oneoaas/assets/css/custom.css
                        patching file ./oneoaas/assets/css/fonts/css/font-awesome.css
                        patching file ./oneoaas/assets/css/fonts/css/font-awesome.min.css
                        patching file ./oneoaas/assets/css/fonts/fonts/FontAwesome.otf
                        patching file ./oneoaas/assets/css/fonts/fonts/fontawesome-webfont.eot
                        patching file ./oneoaas/assets/css/fonts/fonts/fontawesome-webfont.svg
                        patching file ./oneoaas/assets/css/fonts/fonts/fontawesome-webfont.ttf
                        patching file ./oneoaas/assets/css/fonts/fonts/fontawesome-webfont.woff
                        patching file ./oneoaas/assets/css/fonts/fonts/fontawesome-webfont.woff2
                        patching file ./oneoaas/assets/css/fonts/glyphicons-halflings-regular.eot
                        patching file ./oneoaas/assets/css/fonts/glyphicons-halflings-regular.svg
                        patching file ./oneoaas/assets/css/fonts/glyphicons-halflings-regular.ttf
                        patching file ./oneoaas/assets/css/fonts/glyphicons-halflings-regular.woff
                        patching file ./oneoaas/assets/css/fonts/glyphicons-halflings-regular.woff2
                        patching file ./oneoaas/assets/css/fonts/less/animated.less
                        patching file ./oneoaas/assets/css/fonts/less/bordered-pulled.less
                        patching file ./oneoaas/assets/css/fonts/less/core.less
                        patching file ./oneoaas/assets/css/fonts/less/fixed-width.less
                        patching file ./oneoaas/assets/css/fonts/less/font-awesome.less
                        patching file ./oneoaas/assets/css/fonts/less/icons.less
                        patching file ./oneoaas/assets/css/fonts/less/larger.less
                        patching file ./oneoaas/assets/css/fonts/less/list.less
                        patching file ./oneoaas/assets/css/fonts/less/mixins.less
                        patching file ./oneoaas/assets/css/fonts/less/path.less
                        patching file ./oneoaas/assets/css/fonts/less/rotated-flipped.less
                        patching file ./oneoaas/assets/css/fonts/less/spinning.less
                        patching file ./oneoaas/assets/css/fonts/less/stacked.less
                        patching file ./oneoaas/assets/css/fonts/less/variables.less
                        patching file ./oneoaas/assets/css/fonts/scss/_animated.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_bordered-pulled.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_core.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_fixed-width.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_icons.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_larger.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_list.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_mixins.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_path.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_rotated-flipped.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_spinning.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_stacked.scss
                        patching file ./oneoaas/assets/css/fonts/scss/_variables.scss
                        patching file ./oneoaas/assets/css/fonts/scss/font-awesome.scss
                        patching file ./oneoaas/assets/css/jquery.datetimepicker.css
                        patching file ./oneoaas/assets/css/oneoaas.css
                        patching file ./oneoaas/assets/css/simplePagination.css
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/1_close.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/1_open.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/2.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/3.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/4.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/5.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/6.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/7.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/8.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/diy/9.png
                        patching file ./oneoaas/assets/css/zTreeStyle/img/line_conn.gif
                        patching file ./oneoaas/assets/css/zTreeStyle/img/loading.gif
                        patching file ./oneoaas/assets/css/zTreeStyle/img/zTreeStandard.gif
                        patching file ./oneoaas/assets/css/zTreeStyle/img/zTreeStandard.png
                        patching file ./oneoaas/assets/css/zTreeStyle/zTreeStyle.css
                        patching file ./oneoaas/assets/img/logo.png
                        patching file ./oneoaas/assets/img/qrcode.jpg
                        patching file ./oneoaas/assets/js/bootstrap.min.js
                        patching file ./oneoaas/assets/js/jquery-1.11.3.min.js
                        patching file ./oneoaas/assets/js/jquery.datetimepicker.full.min.js
                        patching file ./oneoaas/assets/js/jquery.simplePagination.js
                        patching file ./oneoaas/assets/js/jquery.ztree.all.min.js
                        patching file ./oneoaas/assets/js/oneoaas.js
                        patching file ./oneoaas/graphtree.php
                        patching file ./oneoaas/inc/css.inc.php
                        patching file ./oneoaas/inc/func.inc.php
                        patching file ./oneoaas/inc/smarty.inc.php
                        patching file ./oneoaas/libs/Autoloader.php
                        patching file ./oneoaas/libs/Smarty.class.php
                        patching file ./oneoaas/libs/SmartyBC.class.php
                        patching file ./oneoaas/libs/debug.tpl
                        patching file ./oneoaas/libs/plugins/block.textformat.php
                        patching file ./oneoaas/libs/plugins/function.counter.php
                        patching file ./oneoaas/libs/plugins/function.cycle.php
                        patching file ./oneoaas/libs/plugins/function.fetch.php
                        patching file ./oneoaas/libs/plugins/function.html_checkboxes.php
                        patching file ./oneoaas/libs/plugins/function.html_image.php
                        patching file ./oneoaas/libs/plugins/function.html_options.php
                        patching file ./oneoaas/libs/plugins/function.html_radios.php
                        patching file ./oneoaas/libs/plugins/function.html_select_date.php
                        patching file ./oneoaas/libs/plugins/function.html_select_time.php
                        patching file ./oneoaas/libs/plugins/function.html_table.php
                        patching file ./oneoaas/libs/plugins/function.mailto.php
                        patching file ./oneoaas/libs/plugins/function.math.php
                        patching file ./oneoaas/libs/plugins/modifier.capitalize.php
                        patching file ./oneoaas/libs/plugins/modifier.date_format.php
                        patching file ./oneoaas/libs/plugins/modifier.debug_print_var.php
                        patching file ./oneoaas/libs/plugins/modifier.escape.php
                        patching file ./oneoaas/libs/plugins/modifier.regex_replace.php
                        patching file ./oneoaas/libs/plugins/modifier.replace.php
                        patching file ./oneoaas/libs/plugins/modifier.spacify.php
                        patching file ./oneoaas/libs/plugins/modifier.truncate.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.cat.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.count_characters.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.count_paragraphs.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.count_sentences.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.count_words.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.default.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.escape.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.from_charset.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.indent.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.lower.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.noprint.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.string_format.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.strip.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.strip_tags.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.to_charset.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.unescape.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.upper.php
                        patching file ./oneoaas/libs/plugins/modifiercompiler.wordwrap.php
                        patching file ./oneoaas/libs/plugins/outputfilter.trimwhitespace.php
                        patching file ./oneoaas/libs/plugins/shared.escape_special_chars.php
                        patching file ./oneoaas/libs/plugins/shared.literal_compiler_param.php
                        patching file ./oneoaas/libs/plugins/shared.make_timestamp.php
                        patching file ./oneoaas/libs/plugins/shared.mb_str_replace.php
                        patching file ./oneoaas/libs/plugins/shared.mb_unicode.php
                        patching file ./oneoaas/libs/plugins/shared.mb_wordwrap.php
                        patching file ./oneoaas/libs/plugins/variablefilter.htmlspecialchars.php
                        patching file ./oneoaas/libs/sysplugins/smarty_cacheresource.php
                        patching file ./oneoaas/libs/sysplugins/smarty_cacheresource_custom.php
                        patching file ./oneoaas/libs/sysplugins/smarty_cacheresource_keyvaluestore.php
                        patching file ./oneoaas/libs/sysplugins/smarty_data.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_cacheresource_file.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_append.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_assign.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_block.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_break.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_call.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_capture.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_config_load.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_continue.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_debug.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_eval.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_extends.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_for.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_foreach.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_function.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_if.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_include.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_include_php.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_insert.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_ldelim.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_nocache.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_block_plugin.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_foreachsection.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_function_plugin.ph p
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_modifier.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_object_block_funct ion.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_object_function.ph p
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_php.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_print_expression.p hp
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_registered_block.p hp
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_registered_functio n.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_private_special_variable.p hp
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_rdelim.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_section.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_setfilter.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_shared_inheritance.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compile_while.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_compilebase.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_config_file_compiler.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_configfilelexer.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_configfileparser.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_data.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_debug.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_extension_clear.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_extension_handler.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_addautoloadfilters.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_adddefaultmodifiers.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_append.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_appendbyref.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_assignbyref.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_assignglobal.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_clearallassign.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_clearallcache.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_clearassign.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_clearcache.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_clearcompiledtemplate.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_clearconfig.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_compileallconfig.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_compilealltemplates.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_configload.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_createdata.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_getautoloadfilters.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_getconfigvars.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_getdebugtemplate.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_getdefaultmodifiers.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_getregisteredobject.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_getstreamvariable.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_gettags.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_gettemplatevars.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_loadfilter.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_loadplugin.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_mustcompile.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registercacheresource.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerclass.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerdefaultconfighandle r.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerdefaultpluginhandle r.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerdefaulttemplatehand ler.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerfilter.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerobject.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerplugin.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_registerresource.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_setautoloadfilters.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_setdebugtemplate.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_setdefaultmodifiers.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_unloadfilter.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_unregistercacheresource.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_unregisterfilter.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_unregisterobject.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_unregisterplugin.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_method_unregisterresource.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_nocache_insert.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree_code.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree_dq.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree_dqcontent.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree_tag.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree_template.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_parsetree_text.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_eval.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_extends.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_file.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_php.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_registered.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_stream.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_resource_string.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_cachemodify.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_codeframe.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_filterhandler.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_foreach.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_getincludepath.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_hhvm.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_inheritance.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_subtemplate.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_tplfunction.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_updatecache.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_updatescope.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_validatecompiled.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_var.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_runtime_writefile.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_smartytemplatecompiler.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_template.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_templatebase.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_templatecompilerbase.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_templatelexer.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_templateparser.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_testinstall.php
                        patching file ./oneoaas/libs/sysplugins/smarty_internal_undefined.php
                        patching file ./oneoaas/libs/sysplugins/smarty_resource.php
                        patching file ./oneoaas/libs/sysplugins/smarty_resource_custom.php
                        patching file ./oneoaas/libs/sysplugins/smarty_resource_recompiled.php
                        patching file ./oneoaas/libs/sysplugins/smarty_resource_uncompiled.php
                        patching file ./oneoaas/libs/sysplugins/smarty_security.php
                        patching file ./oneoaas/libs/sysplugins/smarty_template_cached.php
                        patching file ./oneoaas/libs/sysplugins/smarty_template_compiled.php
                        patching file ./oneoaas/libs/sysplugins/smarty_template_config.php
                        patching file ./oneoaas/libs/sysplugins/smarty_template_resource_base.php
                        patching file ./oneoaas/libs/sysplugins/smarty_template_source.php
                        patching file ./oneoaas/libs/sysplugins/smarty_undefined_variable.php
                        patching file ./oneoaas/libs/sysplugins/smarty_variable.php
                        patching file ./oneoaas/libs/sysplugins/smartycompilerexception.php
                        patching file ./oneoaas/libs/sysplugins/smartyexception.php
                        patching file ./oneoaas/templates/graphtree/graphtree.tpl
                        patching file ./oneoaas/templates/header.tpl
                        /usr/share/zabbix# chown -R root:root oneoaas
                        Sorry but don't work
                        Not Found
                        The requested URL /oneoaas/graphtree.php was not found on this server.
                        I'm doing something wrong.... again
                        • itnihao
                          • Aug 2013
                          • 12
                          thanks,the problem is absolute path,
                          you URL is
                          the real path is
                          we use absolute path in PHP code
                          we will fix it and publish again
                          • itnihao
                            • Aug 2013
                            • 12
                            Fix it,you can try https://github.com/OneOaaS/graphtrees
                            • sancho
                              • Mar 2015
                              • 301
                              #15
                              Hi again and thank you very much for your work,
                              After changes you indicated, no longer fails but only redirected to an empty page
                              The URL to which you redirect is http://xxx.xxx.xxx.xxx/zabbix/oneoaa....php?ddreset=1
