PATCH: Russian translation (need help)
  • hiddenman
    • Dec 2005
    • 18
    Hi all.
    Yesterday i've almost finished russian translation. Before posting patch i would like to comminicate with some russians (can't find adequate translation for some strings)
    Please, mail me [email protected]
  • hiddenman
    • Dec 2005
    • 18
    First version
    Ok, this is a first version of the russian translation. Waiting for bugs, mistakes, suggestions etc.
    p.s. This version is based on the 1.1.4 en_gb.inc.php file. Will be updated to the 1.1.5 if there are any changes. Encoding is UTF-8
    p.p.s. Btw, there are still some defects in the strings to translate. For example, S_NAME is used both for device and user names, but in russian there is a difference
    My email is [email protected]
    • hiddenman
      • Dec 2005
      • 18
      1.1.5 version with some updates. Could anyone explain me the string "Aggregated periods count" in the graph setting? What does it mean?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Integrated into 1.4.x. Thank you!
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
