Graph Generator for Zabbix
  • rosscarlson
    • Jun 2026
    New to the community - semi-retired from IT management about 5 years ago so only play with my Home Lab these days. Use Claude to vibe code a flexible front end for Zabbix to create graphs out of all the applicable data. Features are:
    • Simple setup: Just needs your Zabbix URL and token
    • Docker based so easy to deploy
    • Easy / Pretty UI to select graphs, colors, etc.
    • Multi-language
    • Multi-Graphs - overlay as many as 6 datapoints from up to 2 different data types on the same graph. See CPU/GPU usage and CPU/GPU temps on the same graph)
    • Historical charts with zoom/move ability
    While I have some coding experience it's been a while so I've let Claude do this for me - just want to be up-front about that. I have the code in a private github right now but if anyone is interested I can break it out. Also happy to consider suggestions/requests, my home lab is only about a dozen machines so it would likely need some UI changes if you had dozens to hundreds.
    rosscarlson/zabbix-graphs | Docker Hub
    (if this is the wrong forum for this apologies, please move/delete/etc.)
    ~Ross
    quick screenshot
  • bbrendon
    • Sep 2005
    • 873
    What is the point of this post exactly?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • rosscarlson
      • Jun 2026
      Uh, to share something I built for myself for free with others who might benefit from it. I guess I thought
      Would have been plenty clear but I guess not. Is there some problem with that?
        • 5002
        People share their stuff, whats wrong with that?
        • bbrendon
          • Sep 2005
          • 873
          Maybe this is your first rodeo? There isn't anything usable in your post. Your docker link goes to a login page. Are you expecting us to vibe code what you made using your screenshot? Also, I'm guessing most people won't be interested in a docker container if that is what you're intending to share.
          • rosscarlson
            • Jun 2026
            Guess I'm just new around here, the forums I frequent when someone has an error in their post someone just mentions it so it can be corrected - seems that's not how you operate.
            The correct link is: rosscarlson/zabbix-graphs - Docker Image
            I'm probably a moron but I see no way to edit my original post to fix the link.
            I'm guessing that rather than being an asshole if they were interested from the images and description I shared they would mention I posted the wrong link so I could fix it. Then again I'm not an asshole so what do I know.
            ~Ross
