PATCH [1.3.9] delta() function can (and does) work with integers too
  • Farzad FARID
    • Apr 2007
    • 79
    I spent a few hours trying to understand why I couldn't calcultate the delta() of an item. I finally debugged the problem and found that delta() only works for floats and not integers!
    The Zabbix documentation is not precise on this point, as it doesn't say which functions support floats, or integers, or both. Could you please update it on this point ?
    As max() and min() support integers, I asked myself why not delta() ? And so I wrote a patch
    It works on a Fedora Core 5 64 bits. I tested it with both the delta(seconds) syntax and the delta(#count) syntax.
    Please consider my patch for inclusion and update the Zabbix documention consequently.
    Regards
  • Farzad FARID
    • Apr 2007
    • 79
    SQL error in the DELTA correction provided in SVN
    Hi Alexei,
    Thanks for including the DELTA patch, but these is an error in your patchset rev 4164 you forgot to delete the word "history" in an SQL query. Here is a patch:
    Index: src/zabbix_server/evalfunc.c
    --- src/zabbix_server/evalfunc.c        (révision 4167)
    +++ src/zabbix_server/evalfunc.c        (copie de travail)
    @@ -757,7 +757,7 @@
            if(flag == ZBX_FLAG_SEC)
    -               result = DBselect("select max(value)-min(value) from %s history where clock>%d and itemid=" ZBX_FS_UI64,
    +               result = DBselect("select max(value)-min(value) from %s where clock>%d and itemid=" ZBX_FS_UI64,
                            table,
                            now-parameter,
                            item->itemid);
    Regards
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      It wasn't me Anyway it is fixed now! Thanks for the super fast response.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
