PATCH [1.3.9] Temporary fix for events logging
  • Farzad FARID
    • Apr 2007
    • 79
    Hi this is a temporary patch for the bug I described here: http://www.zabbix.com/forum/showthread.php?t=6137
    When more than 20 events have been emitted for a trigger, half of the events are not logged anymore.
    Regards
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I've seen your initial report. Thank you! This patch is incorrect as it basically revert incorrect changes I made before. Note that the function is used not only by db.c!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
