Patch to correct problem with triggers on delta (speed per second) items.
PATCH: triggers on delta (speed per second) items
Tags: None
Patch seems to be working on initial testing with delta speed type items. Please let me know if anyone else has success with this patch.
While the patch fixes the original issue, the patch is incorrect. Please wait for an official fix.Comment
My apologies! I didn't notice that the patch fixes update_item(), not add_history() as I thought before.
The patch is absolutely correct! I extended it to eliminate possible divisions by zero and submitted to pre1.4.2. It could be downloaded from www.zabbix.com/developers.php after 10-15 minutes.Comment
I downloaded the latest build and I notice that the changes are in there but for some reason it is doing the same behaviour as before. The function table is showing the lastvalue of the mib and not the delta change of the mib. Trying to see what is going on.Comment
I did some additional fixing today. Please download the latest pre 1.4.2 and let me know if it works for you.Comment
Downloaded and installed the latest Build and everything is working great! Thanks for your help and support. Zabbix gets better by the day.
Excellent! Thanks for your effort
