zbxcomms bug for communication between Solaris and Linux
  • kempkep
    • Feb 2006
    • 18
    The zabbix comms functions are not transmitting important data in network byte order.
    For example the zabbix_sender utility sends the data preceded by a message length stored in a double (64bit) field. Solaris writes this in its big endian format which a Linux server cannot interpret. zabbix _sender times out which fortunately forces and exit at the server end.
    This patch converts the message length to a value in network byte order which means any client and server can understand - regadless of endian-ness.
    After applying recompile agents and server on all platforms.
    --- ./libs/zbxcomms/comms.c-orig 2007-08-16 14:54:49.000000000 +1200
    +++ ./libs/zbxcomms/comms.c 2007-08-16 15:00:20.000000000 +1200
    @@ -303,6 +303,7 @@ int zbx_tcp_connect(zbx_sock_t *s, c
    int zbx_tcp_send_ext(zbx_sock_t *s, const char *data, unsigned char flags)
    zbx_uint64_t len64;
    + uint32_t len32;
    ssize_t i = 0,
    written = 0;
    @@ -319,9 +320,11 @@ int zbx_tcp_send_ext(zbx_sock_t *s,
    len64 = (zbx_uint64_t)strlen(data);
    + len32 = (uint32_t)strlen(data);
    + len32 = htonl( len32);
    /* Write data length */
    - if( ZBX_TCP_ERROR == ZBX_TCP_WRITE(s->socket, (char *) &len64, sizeof(len64)) )
    + if( ZBX_TCP_ERROR == ZBX_TCP_WRITE(s->socket, (char *) &len32, sizeof(len64)) )
    ZBX_TCP_ERR_START "ZBX_TCP_WRITE() failed [%s]", strerror_from_system(zbx_sock_last_error()) ZBX_TCP_ERR_END;
    return FAIL;
    @@ -549,6 +552,7 @@ int zbx_tcp_recv_ext(zbx_sock_t *s, char
    int allocated, offset;
    zbx_uint64_t expected_len;
    + uint32_t explen32;
    ZBX_TCP_START();
    @@ -569,7 +573,8 @@ int zbx_tcp_recv_ext(zbx_sock_t *s, char
    left = sizeof(zbx_uint64_t);
    - nbytes = ZBX_TCP_READ(s->socket, (void *)&expected_len, left);
    + nbytes = ZBX_TCP_READ(s->socket, (void *)&explen32, left);
    + expected_len= ntohl( explen32);
    /* The rest was already cleared */
    memset(s->buf_stat,0,ZBX_TCP_HEADER_LEN);
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for your report and the patch. The patch is incorrect
    The problem was fixed yesterday in pre 1.4.2 code. Please download it from www.zabbix.com/developers.php and let me know if it works.
    Thank you!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
