based on the changes I already posted in http://www.zabbix.com/forum/showthread.php?t=8116 I added system.cpu.num for OpenBSD. I copied my changes to trunk now, since the codebase in svn seems to be the same in trunk and tags/1.4.2/
sysctl on OpenBSD 4.1 doesn't seem to be able to differentiate between online and max, correct me on that if I'm wrong. I don't have a SMP environment to test it anyways.
So system.cpu.num[whatever] will always return the same value as sysctl -a hw.ncpu:
./src/libs/zbxsysinfo/openbsd/cpu.c
So, please let me know what you think and what you find testing it..
Sebastian
PS: I forgot the "return ret;" at the end.
--- trunk-sra/src/libs/zbxsysinfo/openbsd/cpu.c 2007-10-18 19:47:39.000000000 +0200
+++ trunk/src/libs/zbxsysinfo/openbsd/cpu.c 2007-10-18 18:26:27.000000000 +0200
@@ -23,23 +23,7 @@
int SYSTEM_CPU_NUM(const char *cmd, const char *param, unsigned flags, AGENT_RESULT *result)
- int ret = SYSINFO_RET_FAIL;
- int mib[2];
- long ncpu;
- size_t len;
- mib[0] = CTL_HW;
- mib[1] = HW_NCPU;
- len = sizeof(ncpu);
- if (sysctl(mib, 2, &ncpu, (size_t *) &len, NULL, 0) == 0)
- SET_UI64_RESULT(result, ncpu);
- ret = SYSINFO_RET_OK;
- return ret;
+ return SYSINFO_RET_FAIL;
static int get_cpu_data(unsigned long long *idle,
Sebastian
