PostrgreSQL solution for images.
  • rcats
    • Oct 2007
    The Solution for uploading images with a progress databases is changing the return query of the postgreSQL database in file "includes\images.inc.php":
    In function: function add_image($name,$imagetype,$file)
    else if($DB_TYPE == "POSTGRESQL")
    $image = pg_escape_bytea($image);
    return DBexecute("insert into images (imageid,name,imagetype,image)".
    " values ($imageid,".zbx_dbstr($name).",".$imagetype.",'".$image."')");
  • joggl62
    • Jan 2008
    syntax error
    Thanks for the solution.
    Now i get the following errors.
    Wath can be the solution for this? any idea? :
    invalid command \221J
    invalid command \376s
    invalid command \'
    invalid command \'
    invalid command \036
    invalid command \275
    invalid command \223
    invalid command \'
    invalid command \003
    invalid command \370$
    invalid command \242
    invalid command \306
    invalid command \274
    invalid command \262i
    invalid command \000
    invalid command \'
    ERROR: syntax error at or near "INSERT"
    LINE 2: INSERT INTO images VALUES (2,1,'Hub (small)','\211PNG\015\01...
