[FIX] discovery set-hostname_get-sysName
  • eric_at_2037
    • May 2008
    • 12
    This subject is a translation of this original article in French : http://it.2037.biz/viewtopic.php?t=8907
    When you use the discovery functionality by default host discovered is named by their IP address. This php script list all hosts and try to get sysName by SNMP.
    Before executing, make sure that you have understood what the script does! druleid must be correctly set.
    Regards,
    Eric
    PHP Code:
    <?php
    # Ce script distribué sous la licence GNU FDL a été développé a l'origine par Eric B
    # Site officiel du script : http://2037.org/ || http://it.2037.biz/viewtopic.php?t=8907
    # Permission vous est donnée de distribuer, modifier ce script tant que cette note apparaît clairement
    # Version 1.0.0 du 19 mai 2008
    // the name of snmp community
    $C_COMMUNITY = "public";
    // connexion to MySQL database server
    $db = mysql_connect('mysql_server', 'mysql_user', 'mysql_password')  or die('Erreur de connexion '.mysql_error());
    // select  MySQL base
    mysql_select_db('zabbix',$db)  or die('Erreur de selection '.mysql_error());
    // select dhost
    // druleid is the id of the discovery rule, see table drules
    $sql = "SELECT * FROM `dhosts` WHERE `druleid` = '3'";
    $result = mysql_query($sql) or die('Erreur SQL !'.$sql.'<br>'.mysql_error());
    // for each result we get the device name by snmp and update the record in the database
    while ($row = mysql_fetch_assoc($result))
    $C_IP = $row['ip'];
    $sysName = snmpgetclear(".iso.org.dod.internet.mgmt.mib-2.system.sysName.0");
    // if result is too long or too short nothing is done
    if(strlen($sysName) < '64' AND strlen($sysName) > '3')
    $sql2 = "UPDATE `hosts` SET `host` = '{$sysName}' WHERE `ip` = '{$row['ip']}' LIMIT 1;";
    $result2 = mysql_query($sql2) or die('Erreur SQL !'.$sql.'<br>'.mysql_error());
    // the end
    echo 'script done !';
    // On format la response SNMP
    function snmpgetclear($oid)
    $invar = snmpget($GLOBALS['C_IP'],$GLOBALS['C_COMMUNITY'],"$oid");
    $var = eregi_replace("STRING: ","",$invar);
      return
    eregi_replace("\"","",$var);
  • eric_at_2037
    • May 2008
    • 12
    Add SLA
    Before executing, make sure that you have understood what the script does! druleid and function parameter add_service must be correctly set.
    PHP Code:
    <?php
    # Version 1.0.0 du 21 mai 2008
    // select dhost
    //echo $row['ip'] . "\n";
      // get hostid itemid triggerid
    $sql2 = "SELECT * FROM `items` AS i, `hosts` AS h, functions AS f WHERE h.ip = '{$row['ip']}' AND h.hostid = i.hostid AND i.key_ = 'icmpping' AND i.itemid = f.itemid";
    $row2 = mysql_fetch_assoc($result2);
    // echo $row2['triggerid'] . "\n";
    $result3 = mysql_query("SELECT COUNT(*) FROM services WHERE triggerid = '{$row2['triggerid']}'");
    $row3 = mysql_fetch_assoc($result3);
    // service is not already set for this dhost
    if($row3['COUNT(*)'] == '0')
    //echo "on s'occupe de {$row2['host']} - {$row2['triggerid']}\n";
    include_once "include/config.inc.php";
            include_once
    "include/services.inc.php";
    /* add_service(
           $_REQUEST["name"],$triggerid,$_REQUEST["algorithm"],
           $_REQUEST["showsla"],$_REQUEST["goodsla"],$_REQUEST["sortorder"],
           $service_times,$_REQUEST['parentid'],$childs);
    echo add_service($row2['host'],$row2['triggerid'],"0","1","99.05","0","","14","");
    // the end
