snmpbulkget
  • riegersteve
    • Oct 2004
    • 68
    snmpbulkget
    Alexi, i am currently monitoring about 1000 servers, 300 cisco devices, and about 200 printers, i would like to know if you can add in the setup fr an anmp host that zabbix should do a snmpbulkget and store all the avaliable oids as snm vriables that should be monitored. it would be easy to then fo through and remove the ones that are not required.
    the reason for this, most hosts have certain snmp variables in common, but they all have something that the other ones do not have, and for me to have to do an snmpbulkget via commandline and then add the things one by one to each host takes a really long time.....
    thanx
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Will hard-linked templates (to be introduced in v1.1) be handy in your situation? You change one template-host, and the changes will automatically be propagated to corresponding linked real hosts.
    By the way, just wondering, how many active items and triggers you have?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • riegersteve
      • Oct 2004
      • 68
      about 1000 server * 15 items on each server = 15000
      300 cisco * about 20 items on each = 5000
      200 printers * about 5 items each = 1000
      total about 20000 - 22000
      • riegersteve
        • Oct 2004
        • 68
        will i be able to run a snmpbulkget and add everything into a template in v1.1
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I don't know yet. I've been thinking a couple of days about possible approach for import/export, no good solution yet. I think that I'll go XML way by providing a small utility (or a WEB form) which would perform required operations.
          This would enable ZABBIX users to exchange templates for hosts/apps/devices easily. I could even create a repository of templates on http://www.zabbix.com.
          Alexei Vladishev
          My Twitter
          • LEM
            • Sep 2004
            • 112
            Excellent idea: similar to Microsoft MoM's 'management packs'. easing exchange of these 'monitoring kits'/template/'management packs' between users of zabbix is definitively a really good thing !
            LEM
            • limo
              • Dec 2004
              • 192
              Very nice idea to use xml
              It is very good idea, maybe it would be nice to export data from graphs and latest data too. Would be great.
