zabbix - switch monitoring
  • RohrbaGe
    • Aug 2005
    • 167
    I'm using zabbix since several years now and during the years it has
    become much more comfortable. The basic idea to use a database as backend
    is a big advantage to several other solutions, that's why I switched some years
    ago over from nagios to zabbix.
    I'm monitoring about 20 servers and about 20 Cisco switches and about 100 IP phones,
    door control system ..... About 2000 items.
    But still not everything is covered, ( or I did not found an easy way)
    As I have started working in a new company, where nothing was documented,
    I even had problems to discover the switches and connections.
    I found a very good Tool NEDI, that can discover switches, their connections and
    a lots of information about the network. Also this tool is writing to a mysql database.
    Basicly it is written in perl, the frontend is PHP.
    Some of the information I get aldready with Zabbix, but what I like very much
    is, that I get a db entry by switch/port/mac address.
    The guy , that has developed this tool has spend some years in development.
    As I have cisco switches in use, it works perfect for me. But it should also
    work for other (managed) switches.
    With the MAC Table I can find much easier a device, I know now the port of the switch.
    Maybe someone of the developers can look at it, and can get some good ideas.
    The installation of NEDI is not too complicate and quite good documented.
    Gerald
  • jobster
    • Sep 2008
    has anyone found a way to export devices and their connections from nedi and import them to zabbix, i need to add about 400 switches and routers to my zabbix-installation and the prospect of manually adding dependencies to zabbix does not really amuse me....
    • troffasky
      • Jul 2008
      • 639
      Gerald
      I prefer Netdisco, as it doesn't duplicate any of Zabbix's functionality, and is packaged in Debian.
