groupnesting
  • Filter
    groupnesting
    Here is something I can really use, I created a improvement in JIRA for this but apparently this is a better place to post feature requests.
    It would be nice to allow nesting of groups. This means that groups can be part of other groups.
    Example:
    Group A contains group1 and group2
    group1 contains host1 and host2
    gropu2 contains host3 and host4
    In the overview you can choose between these groups, meaning the 4 hosts or just 2 of them.
    This can be useful if you have a lot of hosts and want to order them a bit.
    Greetings Johan
    As far as I know, host groups cannot contain other host groups.
    But one host can be member of many host groups.
    So you can "emulate" the behaviour you described but it requires a bit more work and is not as flexible/clean (you would have to add host1 to group1 and groupA...).
      How would you implement permission schema for the nesting groups?
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
        I see 2 possibilities:
        If you have permission to all the sub-groups, you can see the group containing the different groups.
        -and/or-
        Just see the group containing the other groups as a normal group where you can put permission on.
        Maybe this can not just be called group, but group-container (or something like that). This group-container can only contain groups, thus no hosts. Which will make the handling a bit more easier.
          search for "nested" in http://www.zabbix.com/wiki/doku.php?id=contrib:ideas
          Zabbix tips and inspiration (blog)
          Announcement
          No announcement yet.
