Configuration of Actions
  • geno
    • Nov 2008
    • 29
    After my whole exploration of how escalations and recovery messages work (http://www.zabbix.com/forum/showthread.php?t=11433), I thought of two things that could add more flexibility.
    Img 1
    Replacement of default recovery message
    When you edit an operation you can choose not to use the default message by unticking the box and then filling in a replacement subject and message body.
    It would be nice if one could do the same with the recovery message.
    Why?
    Lets say you send a notification to an email address in Step 1; here you put in lots of details of the incident since its email. Then in Step 2 (the escalation after time period) you want to send an escalation message to a cellphone. But because one text message is limited to around 160 characters, you do not use the default message and fill in a replacement message which is shortened version.
    You might also want to have a shortened version of the recovery message that will go to the cellphone?
    Currently I just have a short default recovery message, which seems to work good enough. Will see over time.
    Img 2
    More control over logic in conditions
    In img 1 you can see what it currently looks like when you setup the conditions for the action. If I choose "AND/OR" it will fill do it as shown. If I choose "AND" everything becomes 'and' [ (a) and (b) and (c and d and e) ]. With 'or' everything becomes 'or' [ (a) or (b) or (c or d or e) ].
    But what if I want to have
    [ (a) and (b) and (c or d) and e) ]
    Zabbix doesn't allow this at the moment?
    With this screenshot I might want to have logic that does the following:
    ACTION A
    IF [App Dev Host Group]
    AND
    [JBOSS Availability trigger fires]
    AND
    ( [for items marked with A_BACKEND] OR [items marked with A_CALCULATIONS] )
    AND
    [for items marked with A_NOT247]
    AND
    [time is between 06:00 and 18:00]
    THEN <fire action>
    I would setup another action
    ACTION B
    AND
    AND
    So some items might be marked with only 'A_BACKEND' and some might be marked with 'A_BACKEND' and 'A_NOT247'.
    This way I can differentiate between them and setup actions accordingly.
    But then again, maybe there's another solution
  • phasevelocity
    • Dec 2008
    • 9
    Thanks for your work, I will try these things once I get things setup correctly.
