Map Links
  • SparHawk
    • Oct 2004
    • 19
    Map Links
    Something that I have noticed is that you have to define a link status for ON and OFF, would it be possible to have the functionality to only select a link status for ON or for OFF (eg when the router is up (trigger OFF) there is no link line and when the router is down (trigger ON) the link line is a colour like RED).
    I'am using satelite images to indicate routers out in my region and having a white (any colour) line running over my map when the triggers are OFF does not look nice, I only want to indicate when the trigger is ON. Would also suggest to include more colours or be able to define your own colour.
    Alexei, just want to say great work, brilliant app.
    SparHawk
