Zabbix, Jabber and Gtalk
  • alfiere
    • May 2008
    • 51
    As far as I know Zabbix doesn't support Gtalk.
    I'm able to interact with different Jabber servers, but "talk.google.com" is not one of them.
    Googling around I found this useful link:
    With this script
    Temukan pengalaman bermain slot gacor hari ini di RVIP1.Situs slot online terpercaya ini punya link alternatif anti blokir, bisa diakses lewat H5 atau download APK Android, dengan proses yang cepat dan jackpot terbesar.
    is possible to send messages thought gtalk, I suppose should not be so hard to integrate everything inside the Zabbix core.
    my 2 cents.
    Thanks and Cheers,
    Alf
  • Tenzer
    • Nov 2007
    • 316
    Since nothing in Zabbix is build on Perl, it would be odd (imo) to include this into the core package. Instead I would recommend you to use it as an external alert script, it is very easy to set up.
    • alfiere
      • May 2008
      • 51
      UPDATE
      After a quite long investigation, I can say:
      Google Gtalk is completely inter operable with the Jabber network.
      1. I registered a free account with jabberes.org (jabber.org seems not working with gtalk)
      2. From gtalk client or from gmail page u need to add the new account [email protected]. In this way the jabberes.org server will automatically provide to authorize the gtalk invitation.
      3. In the Zabbix GUI:
      Administration->Media types->Create Media types->
      Type: Jabber
      Jabber Identifier: follow the schema user@server. In our case [email protected]
      password: of course the [email protected] password
      4. Now, in Administration->Users->"select your user" and insert the jabber media created.
      "send to" will be your [email protected] account.
      During my test I encountered two different problems:
      1. Some jabber servers (jabber.org for example) don't accept the gtalk invite... the request remain always pending
      2. Not all the interactions with the Zabbix GUI are well understood from the zabbix server. I mean, to be sure to commit a change (made by the GUI) I strongly suggest to restart zabbix_server
      Cheers,
      Alf
      • ipguy
        • Nov 2010
        • 12
        Originally posted by alfiere
        UPDATE
        Type: Jabber
        Cheers,
        Alf
        so how does this work if the jabber.org don't accept the gtalk invite ?
        • vins
          • Feb 2009
          • 31
          this is the script i use for gtalk alerts: (it needs some cpan modules!)
          #!/usr/bin/perl
          use strict;
          use warnings;
          use Net::Jabber;
          use POSIX qw(strftime);
          my $recip = shift @ARGV;
          my $mensaje = join ("\n",@ARGV);
          my $room = "";
          if ($recip=~m/\@conference/)
          ($room)=$recip=~m/(.*)\@conference/;
          my $jserver="talk.google.com";
          my $jport="5222";
          my $domain="gmail.com.";
          my $user="zabbix-alerts"; # gtalk user authentication
          my $pass="zabbix-alerts";
          my $nick="Zabbix Alert";
          my $con = new Net::Jabber::Client();
          sub Msg($) {
          chomp($_[0]);
          if ($room)
          $con->MessageSend(to=>$recip, type=>"groupchat", body=>$_[0]);
          } else {
          $con->MessageSend(to=>$recip, type=>"chat", body=>$_[0]);
          my $status = $con->Connect(hostname=>$jserver,port=>$jport,connectio ntype=>'tcpip', tls=>'1',componentname=>'gmail.com');
          defined $status or die "can't connect ($!)";
          my @result = $con->AuthSend(username=>$user, password=>$pass, domain=>$domain, resource=>"$0-$$");
          $result[0] eq "ok" or Stop("$result[0] $result[1]");
          $con->RosterGet(); # tell server to send presence info
          $con->PresenceSend(); # tell world that we are logged in
          if ($room)
          $con->MUCJoin(room=>$room, server=>"conference.$jserver", nick=>($nick||$user));
          Msg($mensaje);
          sleep 1;
          $con->Disconnect();
          zabbix@hostname:/home/zabbix/bin# ./jabber.pl [email protected] "sample message"
