Flexibility of screens
  • tchjts1
    • May 2008
    • 1605
    We are heavily dependent on the use of graphs and screens where I work. Being the Zabbix Admin, I create the screens layout and add in the graphs, while other team members do the data analysis.
    The problem surrounding the use of the screens is that they have very little flexibility if you need to modify the layout after they have been created and populated. You are limited to only being able to add rows at the bottom of the screen.
    I try to logically group the graphs on a screen. One typical DB screen may contain upwards of 40 graphs. They are laid out in a grouping similar to this -
    | CPU count | CPU usage | CPU load |
    ___________________________________
    |Memory | Pagefile | Swap space |
    | Disk space | Disk space | Disk Queue |
    You get the idea. So if one of our analysts requests a metric that fits into one of the groupings at the top of the screen, there is no way to put it there. It can only be added at the bottom and that just breaks the flow and rhythm of the data presentation.
    I think what would be an ideal feature here is the way Excel allows you to add a cell to a row or column and allows you to shift cells left or right when inserting.
    Outside of that, it would at least be nice to be able to insert an entire row or column anywhere within the graph.
    Of course, drag and drop would be awesome...
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    We already have a prototype of drag-drop based screen editing implemented in pre-1.8. It is very likely it will be improved even further prior to official release on 1.8.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • tchjts1
      • May 2008
      • 1605
      Thanks Alexei. That is good news.
      A good chunk of my time is spent in the screens area.
      Is 1.8 going to have the ability to clone a screen layout from host to host? Or maybe from template to host? That would save so much time.
