WEB Monitoring - Error: Status code didn't match
  • Filter
    Hello everbody!
    I've got a question about ZABBIX WEB Monitoring.
    I configurated a Scenario, but the Login didn't work.
    My configuration:
    Scenario:
    Application: Hosting Service
    Update interval (in sec): 30
    Agent: IE
    Status: Active
    Variables: {user}=<admin @ domain.ch>
    {password}=<password>
    Steps:
    URL: https://<sharepoint>
    Post: name={user}$password={password}$enter={Enter}
    Timeout: 15
    Required:
    Status codes: 200
    The problem is, in the WEB Monitoring stands Failed on "Login" [1 of 1] Error: Status code didn't match.
    Return Code is 401, but i the Return Code wan't 200.
    Can someone help me?
    Sorry about my English(Switzerland )...
    1/ Are you sure sharepoint accepts authentication from POST variables ?
    2/ Use curl to test you scenario (man curl !). As far as I know, zabbix_server cannot (yet ?) respond to authentication challenges.
      i have same problem. who solved a problem?
        When your Uptrends monitor detects an error, the check detail and monitor logs display an error code based on the event or problem. The following list contains the codes and detailed descriptions for the error codes, and in some cases, the description includes possible causes and corrective actions you may take.
          9apps download
          I think I am also facing this issue. Did you get any proper solution?
          Announcement
          No announcement yet.
