my english is not very well, but i will try to explain.
Info:
Actually, there exist no open source soloution for a cable documentation. But this would be very useful for network-monitoring. Commercial tools cost like 20.000 Eur (or upper).
Suggestion:
At the first, it would be enough to find a easy way to get that.
It must be possible, to create textboxes or labels (left/right/top/bottom) of a cable on the map overview, with short description (e.g. Cat5e 100Mbit).
And if u click on the cable or the short name (detail> e.g. Cat5e 100Mbit), it popup (or shows via ballon tip) the long description?
This feature would be also allow, to create numbers or something like that (for both cable ends). So I can see, if the swith (Host) is down, it could be a cable fault. Now i can look in the cable description (with e.g. Roomname,floor,cable number, port number of the switch, where the cable is plugged in..) and know, which cabel and were the broken-down cabel is.
Optional:
To creat colored cabels with description and a cabel-legend box at one corner.
That feature would be awesome!
Thx for reading
Dennis (soon: electronic engineer)
Info:
Suggestion:
Optional:
Thx for reading
