Are you able to assist with a problem that I have in getting an external script that we previously used with nagios working with zabbix?
The output of my script is as below, this has an exit status of 3
Error: value "blah blah" not found | 2
The number 2 is the time in seconds that the script took to execute. (this needs to be graph-able)
This script also has a exit status of 3 (previously used by nagios) to flag up the error state
and the text "Error... " was then used as the string displayed in the error message.
Is it possible to use this output with zabbix? will i need to modify the script to change the output? or can i use triggers to pick out the bits individually?
Many Thanks
Matt
Many Thanks
Matt
