Upstart Script for zabbix
  • phampson
    • Jul 2010
    • 12
    #16
    Thanks muchly for some reason zabbix-agent wasnt starting for me using /etc/init.d etc.
    This works perfectly
    Just goto do the same for webmin and simplehelp now
    • m0ps
      • Jul 2011
      • 11
      #17
      Originally posted by g.vecchi
      Ok, I've created working configurations files.
      See attachments.
      thx, it works fine for me on ubuntu 10.04.2
      • g.vecchi
        • Dec 2010
        • 44
        #18
        YAW
        Bye
        • xibbaz
          • Jun 2009
          • 74
          #19
          See attachments.
          This script will not be of any help for me as my database is running on a remote machine.
          I will try to adapt it in the next couple of days.
          • ariecc
            • Aug 2012
            if in slackware how i can this script.
            thanks
            • g.vecchi
              • Dec 2010
              • 44
              #21
              @xibbaz: you're right
              @ariecc: I'm sorry, I don't know slackware
              Here updated scripts:
              /etc/init/zabbix-server.conf :
              # zabbix-server - Start zabbix server
              description     "Zabbix Server"
              author          "Vecchi Giovanni"
              start on (runlevel [2345]
              	  and started mysql)
              stop on runlevel [016]
              respawn
              expect daemon
              pre-start script
              	if [ ! -d /var/run/zabbix-server ]; then
                      	mkdir -p /var/run/zabbix-server
                  		chown zabbix:zabbix /var/run/zabbix-server
                  		chmod 755 /var/run/zabbix-server
              	fi
              	ZabbixConfig=/etc/zabbix/zabbix_server.conf
              	DBUser=""
              	DBPassword=""
              	DBName=""
              	if [ -f $ZabbixConfig ]
              	then
              		DBUser=`cat $ZabbixConfig | grep '^DBUser='`
              		DBUser="${DBUser##*=}"
              		DBPassword=`cat $ZabbixConfig | grep '^DBPassword='`
              		DBPassword="${DBPassword##*=}"
              		DBName=`cat $ZabbixConfig | grep '^DBName='`
              		DBName="${DBName##*=}"
              		if [ -n "$DBUser" ] && [ -n "$DBPassword" ]
              		then
              			while [ ! -S /var/run/mysqld/mysqld.sock ]
              			do
              				sleep 1
              			done
              			i=0
              			while [ $i -le 5 ]
              			do
              			mysql -u$DBUser -p$DBPassword $DBName -e "SELECT \"1\"" &> /dev/null
              			MYSQL_EXIT_CODE=$?
              				if [ $MYSQL_EXIT_CODE=0 ]
              				then
              			        	i=6
              		        	else
              			        	sleep 5
              			        	i=`expr $i + 1`
              		        	fi
              			done
                  		fi
                	fi
              end script
              exec /usr/sbin/zabbix_server
              /etc/init/zabbix-server.agent.conf :
              # zabbix-agent - Start zabbix agent
              description     "Zabbix Agent"
              pre-start script
                      if [ ! -d /var/run/zabbix ]; then
                              mkdir -p /var/run/zabbix-agent
                              chown zabbix:zabbix /var/run/zabbix-agent
                              chmod 755 /var/run/zabbix-agent
                      fi
              end script
              start on runlevel [2345]
              respawn
              expect daemon
              exec /usr/sbin/zabbix_agentd
              • ariecc
                • Aug 2012
                maybe some body know run script in slackware
                • bmurtagh
                  • Nov 2012
                  • 10
                  #23
                  Upstart script working on Ubuntu 12.04 & Zabbix 2.0.3
                  Thank you for the base script S. Canchon. I just implemented this on an Ubuntu 12.04, Zabbix Agent source install successfully.
                  Only change I needed to make was the path to the zabbix_agentd executable.
                  Here is my /etc/init/zabbix-agent.conf:
                  author          "S. CANCHON"
                  respawn
                  expect daemon
                  exec /usr/local/sbin/zabbix_agentd
