ICMP ping not works BUT...
  • gergelyk3
    • Oct 2010
    • 32
    I cant use ICMP ping BUT
    1, it is works on 1.6 (currently is 1.8)
    2, checked /usr/bin/fping rihts - everything works fine
    3, tried impping[,,,,] or simple icmp ping
    4, if I use fping in linux command line , it is works
    I start to mad (
    what is the problem.
  • marcel
    • Oct 2010
    • 112
    what does zabbix_serverd.log say about fping?
    marcel
    Zabbix Certified Specialist for Large Environments since 12/2010
    • gergelyk3
      • Oct 2010
      • 32
      Nothing.
      in the zabbix server log I cant find any rows with fping
      • brian
        • Dec 2009
        • 45
        Can you attach a screenshot of the item? I attached mine.
        • gergelyk3
          • Oct 2010
          • 32
          Here is mine
          • gergelyk3
            • Oct 2010
            • 32
            Nobody can help me?
            anyone?
            please
            • Silvery
              • Oct 2008
              • 28
              Same Problem here. Version is 1.8.3
              My OS is Ubuntu 10.04 LTS
              Item "icmpping" always returns 0
              When I try 'fping HOST' with user zabbix (no root permission) on command line it works.
              No hints in zabbix_server.log....
              • Silvery
                • Oct 2008
                • 28
                I've found my mistake...
                In zabbix_server.conf I changed the FpingLocation to the right value. For Fping6Location I used copy and paste and unfortunately I entered FpingLocation=/usr/bin/fping6
                So zabbix was trying to ping with the following command:
                /usr/bin/fping6 -q -C3 -Sx.x.x.x 2>&1 </tmp/zabbix_server_19690.pinger
                If you haven't found the failure yet, try the following:
                Set DebugLevel=4 in zabbix_server.conf and then use this command:
                tail -f "Path for your zabbix_server.log" | grep fping
