Request for feedback (and help) implementing authentication for zabbix agents
  • walterheck
    • Jul 2009
    • 153
    #31
    Well, we're actually in final stages, all we need is testing. I just hired a tester because the amazing feedback from this thread (ahem..) isn't really enough. After we finish it (currently aimed for April 30th) there's still the challenge of getting it into trunk, which is probably a whole new can of worms. We'll see, just don't despair
    Free and Open Source Zabbix Templates Repository | Hosted Zabbix @ Tribily (http://tribily.com)
    • walterheck
      • Jul 2009
      • 153
      #32
      Done, Yay! Please check out the details here. You can find a patch file that patches trunk and instructions on what we built exactly: http://zabbix.org/wiki/Active_agent_authentication
      • ssureshot
        • Aug 2012
        • 11
        #33
        patch issue
        When I'm applying to the downloaded src I am getting an error with
        create/src/schema.tmpl since there is no directory of create in the source code tree, I have checked svn and it is there but I am unfamiliar with svn.
        The patch updates everything else except the schema.tmpl file.. I assume that since this file isn't updated the schema for the databases doesn't get updated with the proper fields, correct? this would invalidate the patch.
        I'm looking for guidance.
        • richlv
          • Oct 2005
          • 3112
          #34
          that does sound like you have to apply the patch to svn checkout indeed. https://zabbix.org/wiki/Get_Zabbix might provide some initial hints
          • ssureshot
            • Aug 2012
            • 11
            #35
            This patch introduces an error when bootstrap.sh is run,
            configure.in:1389: required file `src/libs/zbxauthcache/Makefile.in' not found
            • yassine
              • Dec 2009
              • 10
              #36
              I managed to successfully install both the server and the agent on debain (squeeze) machines.
              I have also set the autentication bit on (enabled) on both sides.
              But the UI shows "Get value from agent failed: cannot connect to [[client_ip]:10050]: [111] Connection refused"
              Btw, I have tried pinging ant "telnet" the client form the server machine, and that goes through fine.
              I have turned on logs (debug mode), but I am not seeing anything...
              Please advise,
              • zabbix_user2012
                • Aug 2012
                • 13
                #37
                Any plans to merge this patch with the official code?
