Beta 7 Templating
  • Dave Miller
    • Feb 2006
    • 10
    Beta 7 Templating
    I like the option of linking a template to a host and not being able to make changes to the linked host items, in Beta 7. But, this needs to be an option. The Beta 6 linking was actually copying from template to host. The Beta 6 concept needed tweaked not eliminated. I would like to roll out Zabbix for many of my clients. I need to be able to copy temples to hosts or hosts to templates, make changes, then “hard” link to a template, if desired. Zabbix is a great product. It needs to be flexible, if it is going to scale.
  • raycast
    • Mar 2006
    More Beta7 templating
    I really favour templating, however I don't like the "single inheritance" approach of Beta7.
    My "model" is totally based around services; I'd like to have templates for certain services on hosts.
    E.g. a template "Mail server" which contains items like the smtp probe, a template "MySQL", a template "web server".
    That way I can easily have mail servers which have a basic web server, too. Or web servers with and without MySQL. And mail servers with no web server, but MySQL. And pure MySQL servers.
    The current inheritance model would mean that I need to do
    web
    web -> web+mysql
    mail
    mail -> mail+mysql
    mail -> mail+mysql -> mail+mysql+web
    mysql
    With in this simple example the web probes defined in both "web" and "mail+mysql+web", and the mysql probes in both "web+mysql" and "mail+mysql" and "mysql".
    Another issue I'm facing is with interfaces, maybe you can give me a hint here.
    In one of the hosts, the network interface on the main board just died. We simply put in a second interface and the machine is back up. However, this machines "important" SNMP interface ID is now different. Any easy way to override the "relevant" interface number on a per-host basis?
    • crs9
      • Feb 2006
      • 35
      I spent days and days working on my templates for beta7 and once I was happy with my template layout, everything deployed easily and quickly. I personally like the new system better. Raycast, I had a similar situation so I just disabled the items I didnt want on that specific host and then added the new host specific items like normal. I actually added more items to my templates then needed just so I could diable those things I didnt want.
      • raycast
        • Mar 2006
        disabling services
        The overview->triggers page shows my disabled services as being down, in red. Not really an option for me then...
        • edeus
          • Aug 2005
          • 120
          I suspect we are going to have to live with the templating as-is. I still cannot understand why it has been done this way. I am totally against the "new" way of doing item linking.
          Everytime I want to monitor say, Free Disk space on C:\, I need to manually create this item over and over again? If the item parameter changes, as Zabbix items often do, I will need to manually go through and update each item! OMG!!!
          I *have* to be missing something here. It cannot be this dumb, it defeats the purpose of having templates entirely. Please help my stupidity!
          • ekenberg
            • Mar 2006
            • 21
            edeus: This is just what you don't have to do with the new templating. Just add "Free diskspace on C:\" to a template and link all the hosts to this template and you're set. Changes made to the template immediately affect all the relevant hosts. No manual repetition needed.
            • edeus
              • Aug 2005
              • 120
              Ahh sorry. A lot has happened since I last looked at the problem - my mind wasnt thinking straight.
              I see what some people mean by having to have duplicated items and just disable them as required.
              I guess it would work - justs means that for every single unix server I have around 200 items, and 75% disabled per server. I guess this doesnt cause much excess server load?
              Can someone confirm that disabling an item on the host level will not reenable when the template is updated? It would be a bit annoying if disabled items were just continually rechecked.
              Thank you ekenberg! I knew I had to be thinking "dumb". I was so used to creating with multiple templates, the whole idea of having a virtually universal template escaped me. This method is still frustrating but as long as it works and makes it easier for the zabbix team to keep templates working, I am happy.
              • raycast
                • Mar 2006
                templating by disabling
                And of course that it totally sucks to disable 75% of items whenever you add another host.
                I also still would really like to have a way to use variables, like "primary network interface", for graphing and such.
