Edit: since I wrote this I discovered that units of "B" have a divisor of 1024 but that other units such as "Bytes" have a divisor of 1000. I changed my units to "Bytes" instead of "B" and now it reports correct numbers. But that's really confusing behavior. Thanks, Kevin
It's nice that Zabbix automatically converts units on big numbers such as B to MB or GB. But 1024 is the wrong divisor to use in every case except RAM. There needs to be a way to specify a units divisor of 1000 instead of 1024.
Disk space is always measured by the manufacturers with a divisor of 1000. Only for RAM, and for some software, does K mean 1024.
The problem gets worse for bigger number due to repeated division.
For example, we have NAS storage which reports a size of 8388016408 kBytes. That's 8.388 TB. If I use the correct multiplier of 1000 and specify units in "B", Zabbix will divide by 1024 4 times, and report a size of 7.63 TB. If I use a multiplier of 1024, as some suggest, Zabbix will report 7.81 TB.
If I knew that Zabbix will always do a certain number of divisions, I could compensate with a custom multiplier. But that's really hokey, and it doesn't help if I don't know how many divisions will occur, such as disk space used.
Maybe there is already a way to do this, but if so I haven't found it.
Please consider this for a future release.
Thanks, Kevin
Thanks, Kevin
