Ability to get packet loss and change icmp packet size
  • limo
    • Dec 2004
    • 192
    Hello all,
    does anybody has solution to monitor packet loss? It is very usefull especialy in wifi networks. Next, would be nice to set length of icmp packet sent.
    Any suggestions ?
    Thanx.
    Lukas
  • mike_k
    • May 2006
    • 18
    And not only loss from server side, but loss and RTT time from one of the nix monitored clients. For example from gateway to several IPS's, etc. It would be great to have such features available within zabbix client (+ having fping installed on monitored host). Please, consider this...
    For now I am using some ugly scripts (bash+sed+awk), inspired by examples from mrtg for that purpose and wouldn't like to show such a mess =(. The downside is more processes running in endless loop and some some more temp files stored...
    • jameno123
      • Sep 2006
      ICMP Packet Loss
      I would as well like the ability to use the fping results to graph and alarm on packet loss.
      # fping -C3 www.google.com
      www.google.com : [0], 84 bytes, 1.97 ms (1.97 avg, 0% loss)
      www.google.com : [1], 84 bytes, 2.21 ms (2.09 avg, 0% loss)
      www.google.com : [2], 84 bytes, 2.23 ms (2.13 avg, 0% loss)
      www.google.com : 1.97 2.21 2.23
      0% loss would be a number id like to see to be able to be graphed.
      It would be nice to also be able to pass the number of pings to average:
      like: icmppingsec[5]
      and: icmppingloss[5]
      fping already provides the data, just need to make zabbix smart enough to parse it.
      And if zabbix is smart, it can kill off all 3 checks at the same time instead of checking 3 seperate times... (icmpping, icmppingsec, icmppingloss) call fping once and update all 3 values at the same time...
      • nelsonab
        • Sep 2006
        • 1233
        You'll have to write a script to handle that. You may also want to write a wrapper script that stores the results in a temporary file and will query that file until it expires then fping is executed again and the results file updated.
        This post describes better what I am talking about:
        RHCE, author of zbxapi
        • nelsonab
          • Sep 2006
          • 1233
          Originally posted by limo
          Hello all,
          Any suggestions ?
          Thanx.
          Lukas
          What about using an airPcap device and monitoring the number of retransmits from the AP?
          • jameno123
            • Sep 2006
            Yes yes, i can write millions of 1 line scripts to get the data i need... but the point was.
            Zabbix has a special "pinger" process... that pinger process runs fping, and does nothing but pipe data into fping and read its response, continously...
            If zabbix is smart enough to "Send pings to the pinger" -- it should be smart enough to read all packetloss values that the pinger returns and update the items that match.
            Even if it sends 2 ICMP ping sets, 1 for latency and 1 for loss, it wouldnt be a problem for me... Though one could say, this is unoptimal... Its better than forking off some shell scripts when zabbix is already designed to retreive data in better methods.
            so we just need to make zabbix smarter!
            • nelsonab
              • Sep 2006
              • 1233
              "I will replace you with a very small script..."
              • bbrendon
                • Sep 2005
                • 873
                This might be useful.
                Unofficial Zabbix Expert
                Blog, Corporate Site
