Range of values for RefreshActiveChecks
  • Epiliptik
    • Sep 2011
    • 13
    In zabbix_agentd.conf, RefreshActiveChecks has to be set between 60seconds and 3600seconds,why not until 1hours or 1 day, or even more?
    I think one of the best advantage of the passive agent is to reduce network traffic and if you check every 10min, isn't it too heavy?
  • richlv
    • Oct 2005
    • 3112
    in this part of the world, 3600 seconds is one hour
    depends on the size of the environment. usually that is not a concern until you get above several thousands of active agents. if you indeed feel that one hour is not long enough, feel free to open a new feature request in the tracker
    • Epiliptik
      • Sep 2011
      • 13
      Yes 3600s is one hour^^ my mistake!
      So i think for my network with about 100 computers, RefreshActiveChecks every 3600s should be light enough!
      What is the "tracker"?
      • richlv
        • Oct 2005
        • 3112
        if you are ok with updates to item config taking up to one hour, of course.
        tracker is the zabbix issue tracker at https://support.zabbix.com/browse/
