Alternative to using RDBMS
  • hendra
    • Jul 2012
    Hi All,
    I'm new to Zabbix and I have a concern of using relational database to store transactional/historical data in it which will eventually grow over the time. Does anyone have any good strategy to address this?
    Another concern, if the database server crash, will the main monitoring function still works (i.e monitoring availability of other hosts and services and then sending alerts) or do I need a separate tool just to monitor Zabbix's database?
    Thanks in advance.
  • jruizjimenez
    • Jul 2012
    • 10
    You can read about Zabbix Database size on the manual
    http://www.zabbix.com/documentation/...#database_size
    Take a look also at server configuration file for Housekeeping parameters (i.e
    HousekeepingFrequency)
    I will suggest to use a dedicated database server for Zabbix, and monitor the Zabbix and database server.
    I believe you can easily monitor Zabbix from other host, take a look at the API.
