It would be very nice to have a new type in a map "item".
So that you cann assign a item-value to a image.
For exampel if you want create a map for one single "switch" and you want to monitor 24-Ports, if the Ports are ofline or online.
you have an Item for this device "device.port1-status" (Integer)
so it would be nice if you can select in a map a type "item" then select a item from host "device.port1-stauts" and say
Value="1" => icon="port_is_online"
Value="2" => icon="port_is_offline"
Value="3" => icon="port_is_testing"
I think it would be a very nice.
Its a way to display custom status on a MAP!
becouse each compony has her own "This i want to monitor" and with this feuture you can do this.
reg. zabbixx
reg. zabbixx
