Problem with collecting data after chaning to master / child mode
  • shyperets
    • Jul 2012
    VERY CRITICAL PROBLEM ,
    After following this process : http://www.zabbix.com/documentation/...nitoring/nodes , all process finished succesfully
    the backup completed , I am starting to change the configuration
    [18:22:20] Shay Perets: [root@zabbix backups]# /usr/local/sbin/zabbix_server -n 1 -c /etc/zabbix/zabbix_server.conf
    Dropping foreign keys .................................................. .................................................. ..................... done.
    Converting tables .................................................. .................................................. ... done.
    Creating foreign keys .................................................. .................................................. ..................... done.
    Conversion completed successfully
    zabbix server was started after that off course .
    but I dont get any new data from my nodes , ( I didnt connect the child node yet . )
    Edit/Delete Message
  • RobSimons
    • Nov 2012
    Did you renumber the server in the config file
    Look for the following section in the zabbix_server.conf file and adjust the NodeID value to match the database value for which you want the process to collect data and store in the db.
    ### Option: NodeID
    # Unique NodeID in distributed setup.
    # 0 - standalone server
    # Mandatory: no
    # Range: 0-999
    # Default:
    # NodeID=0
