Web Check http PUT method?
  • Mercatus_TECH
    • Jan 2013
    I've been searching the forums trying to understand if we can change the web check http method from POST to PUT for certain types of web check scenarios. We are attempting to monitor/re-create our end user's experience from the web checks. Unfortunately so far I do not see any way to change this method away from POST. Would it be possible at some point to add a drop down selection box for the http Method used for each check. Thus we could mix and match as our sites have been coded. Any info is appreciated.
  • mvalsasna
    • Dec 2023
    Hi
    same issue here, I need to simulate an HTTP PUT request, but I find no way to configure a web monitoring step to create it. any hints? is it supported?
    • skeletor
      • May 2016
      • 12
      I think, zabbix will not designed as PUT tool. It's a monitoring system and the main action - notify. You can write an API on destination host to make changes on it.
        • 5002
        script items https://www.zabbix.com/documentation...emtypes/script and httpRequest object https://www.zabbix.com/documentation...script_objects
