checkbox Select ALL does not work when it should
  • leoh
    • Oct 2005
    • 47
    It's not a bug, I think it's just usability issue. Take a look at this image:
    If I check the first checkbox it does not check all the subsequent checkboxes. Since it is possible to disable a single item in this screen why is it not possible to disable all at once?
    I don't want to disable these itens "globally" inside my template. I just want to disable them here, in this host/item screen.
  • rrupp
    • Jul 2012
    • 21
    Those are all discovered items, Zabbix appears to disable the editing of discovered items as they are managed by the discovery process. Whether that's right/wrong, I'm not sure! Definitely does seem odd when you do select all and it doesn't select everything.
