Hello Sir / Madam,
I used SNMP Discovery rules for Aruba Switch and APs. That rule does get AP Names, but couldn't get other values for each AP. I find that's due to Zabbix use the last session of OID of AP Name. I hope you may modify the program to substring {#SNMPINDEX} including this circumstance.
I've Aruba SNMP values like,
Name/OID: wlanAPName.0.11.134.194.136.230; Value (OctetString): 4F.AP61.253
Name/OID: wlanAPName.36.222.198.192.51.208; Value (OctetString): 6F.AP93.251
Where wlanAPName is .1.3.6.1.4.1.14823.2.2.1.5.2.1.4.1.3.0.11.134.194. 136.230
That OID Value tells me, an AP called '4F.AP61.253' is indexed with '0.11.134.194.136.230' and another called '6F.AP93.251' is indexed with '36.222.198.192.51.208'
Thus I suppose Zabbix will fetch connected clients on an AP by adding a item prototype like,
.1.3.6.1.4.1.14823.2.2.1.5.2.1.5.1.7.{#SNMPINDEX}
However, Zabbix set {#SNMPINDEX} as '208' instead of '36.222.198.192.51.208'. That's the reason related item prototypes fails.
I suggest Zabbix treats {#SNMPINDEX} with remove SNMP OID of discovery rule from SNMP response values. With this method, multi-session or single session {#SNMPINDEX} will work fine too.
Hope this could add to coming release soon!
