Fixes for HPUX >= 10.20
  • afluegel
    • Apr 2013
    please find attached a diff (applicable to version 2.0.5, probably also higher versions), that adds support for system.uptime and system.boottime on HP-UX >=10.20 . It also contains a few fixes to make it compile on this OS, that still must be administrated and monitored in some environments. It would be great to find that in one of the next releases.
    Apply the diff doing:
    prompt# cd zabbix-2.0.5
    prompt# patch -p 1 < /path/to/zabbix-2.0.5.patch
    Thank you very much !
    Yours,
    Albert
  • Heilig
    • Mar 2013
    • 366
    Maybe you should duplicate patch here?
    • afluegel
      • Apr 2013
      Frankly, i don't know how to proceed there. What is meant by duplicate patch ? Post in another forum ? Developers ? Cannot login there or as "customer". Can someone please outline what i should do ?
      Thanks a lot !
      • Heilig
        • Mar 2013
        • 366
        Sign up there and create new issue in the "Zabbix bugs and issues" project. Attach a patch and a description from the first post. Quite simply.
        It is not necessary but it is more likely that developers or users will see your patch.
