How to convert MIBs to snmpwalk output?
  • ronbarak
    • May 2013
    I need to develop a monitoring module, but have no access to the actual device I need to develop for.
    If I had the device's snmpwalk output - I could simulate the device (e.g., with snmposter) and start the development.
    Is there a way to convert the device's MIBs (which I do have) to an snmpwalk output?
    Any ideas would be welcome.
    Ron.
  • Jason
    • Nov 2007
    • 431
    Unless you're practiced at reading the mib file the easiest way is to use the snmpwalk command and specify the mib file to use and then redirect output to a file and look at later... If you run it twice then can have first sith descriptions Nd second time with oid displayed.
