For us (ISP), it would be useful if on maps of the network, where the main elements (M) and the dependent elements (D) are located, with the problem on M, it would be clear which of the D were affected by this problem. For example, if there is a marking on the traced links, or otherwise reflected information, through which it will be possible to assess the scale of the problem at a glance at the ISP network map.
