Web Scenarios
  • scuba
    • Jun 2018
    • 16
    Web Scenarios
    Retries The number of attempts for executing web scenario steps. In case of network problems (timeout, no connectivity, etc) Zabbix can repeat executing a step several times. The figure set will equally affect each step of the scenario. Up to 10 retries can be specified, default value is 1.
    Note: Zabbix will not repeat a step because of a wrong response code or the mismatch of a required string.
    This parameter is supported starting with Zabbix 2.2.
    Is it possible to retry in case of a wrong response code or mismatch of a required string ? I like to try the response 10 times than raise the alarm.
  • LenR
    • Sep 2009
    • 1011
    you can define your trigger to not alert until a condition has existed for the desired number of checks and/or set your action to delay notification. In delayed notification, events will appear on the dashboard before the alert is sent.
    • scuba
      • Jun 2018
      • 16
      You mean attempts ?
